Old 08-29-2007, 05:04 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
I am thinking Cameron has most of the options covered. One more would be to bleed the fronts and make sure you get a steady stream of fluid out of each calipers.
Fill the res. after each bleed so as to not introduce a new problem.
And, If you splash a bit of fluid on the rotors, clean them both anyway as David suggests.
Good luck, I hope this helps.
