Old 08-29-2007, 05:36 AM
slithering slithering is offline
Cobra Make, Engine: Midstates, Genesis 427 S/O
Jahred,
If tape is the only protection from your positive side of the solenoid shorting out, you might consider applying a dab of RTV silicone to the terminal. Just make sure you disconnect the cables from your battery first and allow the silicone to cure before re-installing! This prevents shorts, corrosion and loosened connections.
Chris
"God saved you by His grace when you believed. And you can't take credit for this; it is a gift from God".
Ephesians 2:8
