Thread: getting hot
Old 08-29-2007, 10:00 AM
byron w byron w is offline
Cobra Make, Engine: shellvalley 428 ford
Dragon462,
March makes a hi flow pulley for an FE in single or double groove.
1-groove is # 1552 , 6 inch water pump pulley
2-groove is # 1562 , 6 inch water pump pulley
Note, the crank pulleys are the same diameter for both. Single or double for the high flow and the performance use the same pulley respectively.
I hope this helps and good luck,
Byron
