I used 4x8 sheets of wainscoting on all the walls over the drywall.. I takes the brunt of the the jack handles and anything else that may damage your drywall. Fluorescents are the way to go just make sure you use enough or you can add more if needed. I also ran copper pipe for a compressor to feed a couple of hose reels. It keeps the hose off of the floor and away from the cars when planned out. Never enough peg board even with the 9' span of my work bench. For the work bench top I used two layers of plywood for the top and covered it with galvanized sheets of metal ala home depo. The edge I finished with L shaped steel bar,also great for banging. It's only a 1 1/2 car garage but I was able to build my Cobra in it. Unfortunatly the city would not let me expand it so I was stuck with making the best of it. I took out the ceiling so that I could put a lift in.
