RC,
That is very well done. Very nice indeed. I think you have done a great job so far – you should be proud
You might want to consider a separate electric service box.
You cannot have too much light.
On the ceiling I have:
1. 4 rows of 4 tube fluorescents
2. 16 - 250 watt halogens (this really gets it warm in the winter)
at the top of the walls:
3. Incandescent every 4 feet.
It still could be more—I still need a flashlight sometimes and my area is smaller than yours.
(You might want to consider where you work benches and tools will go before you decide on a final lighting layout)
Same hold true with outlets - every 4 feet at a minimum.
The A/C is a nice touch. Your ceiling are high enough you might want to consider ceiling fans.
I did not use dry wall – I used that fiberboard product that is gloss white on one side. I do not believe I will ever need to paint it. It reflects light well and it will not get damaged if something hits it.
Let me know if you need help assembling the lift.
Again, realy great job!
