Old 08-31-2007, 09:40 AM
cobrarkc's Avatar
cobrarkc cobrarkc is offline
Cobra Make, Engine: Contemporary 482 all aluminum Tunnelport Self built and owned since 1980 frame#0000017 and owner of frame CCX 33961 looking for an FIA body to go with it
Sizzler What ECU are you using? Mass flo uses the Ford A9L from 89-93 5.0 mustangs. Is this going to be SEFI if so you will have to position the injectors over the ports. Are you going to cut out that Bud Moore top to mount the throttlebodies or make a new plate so you can switch it out with the carb top? I'd like to see one done for a Tunnelport do you think that is possible? The pushrod tubes are an issue. I am collecting parts now to make one based on the Mass Flo system for a Cleveland but would like to make one for a Tunnelport. The only way I see is to use throttlebodies with injectors but I would like to make make a SEFI system, any suggestions?
Cobrarich
