Old 09-01-2007, 01:06 PM
Jac Mac's Avatar
Jac Mac Jac Mac is offline
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Smile
Originally Posted by Bill Spain
Jac Mac sounds like you figured out my problem.
First thing I will do is remove the water pump and install a plug. Jac Mac from your post, I assume the pressed in fitting will come out and I can tap the hole for a 1/4" npt plug?
Vettestr I will also perform the test you recommended to see if my expansion tank is installed properly.
Thanks everyone!
Bill,
It will be either 1/4 or possibly 3/8, some pumps have a larger pipe that is swaged down to the heater hose size. If the pump is relatively new it may help to 'nick' the ID of the tube in the pump body with an old hacksaw blade to help collapse it and aid its removal.
Vettstr is correct also in the expansion & header tank concern. I dont know what you have in this area, but if you are thinking of running a remote header tank the fitting you are about to block off would become the recovery from such a system.
Jac Mac
