Joe. If you're going to build it, just plan on spending some time on the build and spread out the expense. For example an ERA kit is around $18,000. Order it with the body bonded to the chasis (as they recommend - all, or most, of their bodies are painted ON the chasis), and it's $19,000. You then assemble and add components as the finances permit. I've been told that you can build a small block ERA for somewhere around $42 (with a standard 350 hp type motor). I don't have the build skills or the time, so mine is a turnkey and will cost somewhat more due to the labor cost added.
