  #34 (permalink)
Old 09-01-2007, 02:19 PM
Rickd Rickd is offline
Joe. If you're going to build it, just plan on spending some time on the build and spread out the expense. For example an ERA kit is around $18,000. Order it with the body bonded to the chasis (as they recommend - all, or most, of their bodies are painted ON the chasis), and it's $19,000. You then assemble and add components as the finances permit. I've been told that you can build a small block ERA for somewhere around $42 (with a standard 350 hp type motor). I don't have the build skills or the time, so mine is a turnkey and will cost somewhat more due to the labor cost added.
