Old 09-02-2007, 02:08 PM
nevermind65 nevermind65 is offline
You are talking about two totally different cases. In #7, you state the engine will not crank at all. That would be related to the starter solenoid or starter itself, assuming the battery is in good shape. If it has an external relay, you can jump the solenoid easily to get the engine to turn over. If the solenoid is mounted on the starter, it can still be done, but is probably a bit harder.
If the engine cranks but doesn't start, then you need to check if it is getting gas to the carb, then check for spark at the plug and at the coil wire. If no spark, then check for power at the coil.
I'm just kind of guessing since you make no mention of whether it has a carb or FI, or what type of ignition is on the car.
