Old 09-02-2007, 07:33 PM
pgermond's Avatar
pgermond pgermond is offline
Originally Posted by olddog
Tank vent goes into the passenger rear wheel well. It is simply an open line turned down. I put a temporary plug in it to see if that made a difference. Didn't help. Don't think it hurt either. I would like to put some type of filter on it to keep unwanted things out.
The sending unit and fuel pump (EFI) all seem dry. I checked it pretty good while the carpet was out. The hoses all look new. All connections seem tight.
You want to maintain that vent. You might check to make sure it's not plugged up. Does the tank have a sending unit mounted on top? Does it only leak/smell when the tank is filled to capacity? I used Permatex Aviation form-a-gasket on all areas of the tank and have never had an issue.
Good luck.
Phil
http://www.uniquecobra.com/
