Old 09-03-2007, 05:21 AM
sideshow sideshow is offline
new cars these days can run into that rpoblem if relays are wired up wrong
anyone fitted yr normal redbattery cut of switch can have these probs
so the proper red keys also have small terminals on ther eto cut coil power
u will see coil power runs thru ignition not thru a relay on most toyotas
so when key is off power is lost on coils andengine stops so alternator stops charging
alt will only charge when spinning anyway so as long as yr relays are wired ok u should be fine
wiring faults usually dont cause engine to keep runnin on a std vehicle
they just make it run bad
my website
www.sideshowsperformancewiring.com.au
