Old 09-03-2007, 05:27 AM
FIA-ERA FIA-ERA is offline
Cobra Make, Engine: ERA FIA 2008/351W/TOP-LOADER
There should be a numbers on the right side of the block above the starter. You will see from the bottom looking up. These will be the casting numbers. They should have numbers like C8... or D2... or E5... etc. The first letter is the decade, "C" = 1960's, "D" = 1970's, "E" = 1980's, etc. The first number indicates the year it was made. Example = "C5...." 1965 was when it was cast. Then it goes on from there, this is the easiest way to identify. After this it breaks down by date and production run, I believe. Thanks, Matt.
