Old 09-03-2007, 10:09 AM
jerry w's Avatar
jerry w jerry w is offline
Cobra Make, Engine: Antique & Collectable 302, C-4,Ford 9 inch
Okay Guys here is what I have done so far:
Pulled the relay, tested it with a battery and test light , relay clicks on. Not the relay
Pulled the starter motor, took it to NAPA they tested it, works fine.
I can turn the engine over with a breaker bar and socket. Engine not seized.
cleaned all ground connections I coud find with emery paper and isopropyl alcohol. There is a ground strap between frame and starter motor bolt on the engine.
When I turn the iginition key, I still get a fast click from the relay, but the starter motor will not turn.
I even tried jump starting the Cobra from a running vehicle, same clicking noise at the relay.
Jerry
