Old 09-03-2007, 10:35 AM
Xavier's Avatar
Xavier Xavier is offline
Cobra Make, Engine: Lonestar LS427, 408w, 48IDA Webers, TKO 600, 9" Currie 4-link 4.11 rear
Default Autometer Gauge Problem
I have the Autometer Cobra replica gauges and have a problem both on my Fuel and Tach gauge. The Tach currently runs directly from my MSD 6AL and steadies at 2krpm, and no lower. It will raise but will not drop lower then 2k. MSD says I can check the output voltage from the 6AL to insure it is between 1-5 VDC for the tach, and it is. Any thing else? Also, fuel sender checks out fine, but fuel gauge does not function. The needle moves when power up the ignition, so it is getting power and sensing something. Fairly simple set up, sender, voltage thats it. The float within the tank on the sender and its movement is set up correctly.
Is there anything else would cause a problem or do I need to send these both back to Autometer for repair?
