Old 09-04-2007, 12:31 AM
Yetiman's Avatar
Yetiman Yetiman is offline
Cobra Make, Engine: Arntz/SBC/Jag
If comparing two units consider the one with the higher CFM rating. Then if there are some that are similar, consider the one that runs the compressor at the lowest RPM (lower RPM, less wear).
If you are still considering multiple models get the one with cast iron cylinders as opposed to iron lined cylinder inserts.
We come into this world naked, screaming, and covered in blood. With dedication and a little planning, you can go out the same way.
View my overflow Gallery (much more to come !)
