Old 09-04-2007, 06:57 AM
Andrew429's Avatar
Andrew429 Andrew429 is offline
Cobra Make, Engine: G-Force MkII, Ford 429, Tremec TKO, Jag Suspension, Sequential LPG Injection, On The Road.
Hi Jbanks,
I have one of the Mk 2 kits.
There are a couple of differences compared with the Mk 1.
The most obvious is the cage around the motor and crossbracing along the length of the driveline tunnel. This replaces the steel tunnel that stephen is running, and is designed to put up with more torque.
The footwell has a steel front (I don't think the Mk 1 has this).
The Mk2 chassis should be heavier (it certainly looks that way).
If you plan on working the motor / giving it some stick, I would have a think about getting the bigger chassis.
Andrew
Andrew
