Old 09-05-2007, 06:19 AM
Joe Wicked's Avatar
Joe Wicked Joe Wicked is offline
Originally Posted by fsstnotch
Hey Joe, If the GM brakes are the only thing keeping you from hurricane.... You can upgrade to willwoods all the way around and still be under the initial cost of a lonestar. Also, I dunno how much you researched, but MANY of the kits come with the GM brakes in fact.. this is what Era gives for part numbers of the brakes you need to buy
the rear are the Jag brakes which would come with the IRS.
I'm pretty sure shell valley also uses the same brake setup.
Thanks. I did not know that. It is not the fact that they are GM brakes, it is is GM up front, SVO in back/Jag in back, etc... If it is a standard brake setup (over the counter) then I would prefer for them to all be GM, Ford, whatever. It just makes it simpler. I realize that this can all be changed, but I am looking for convenience.
