Old 09-05-2007, 12:26 PM
BDHE's Avatar
BDHE BDHE is offline
Cobra Make, Engine: Superformance, PE 514
Originally Posted by BLUE427
BDHE,
I HAVE A 20 FT FEATHERLITE ALUM, WITH THE 2, 4600 LB AXLES, I PUT THE NOSE OF THE CAR JUST PAST THE FRONT WHEEL OF THE TRAILER SO WHEN I OPEN THE SIDE DOOR THE HEADLIGHT AND FRONT PART OF THE FENDER IS RIGHT THERE, MORE TONGUE WT, BUT THATS OK, THE TRAILER DOESNT FISHTAIL AT ALL WITH THE LITTLE EXTRA WT. UP FRONT. I WOULD RATHER BE HEAVY IN THE FRONT THAN THE REAR. I WOULD ALSO SUGGEST GEATTING ALL ALUM, IF YOU CAN AND A V FRONT TO HELP WHAT LITTLE IT CAN ON THE GAS MILEAGE. 20 FT IS PLENT BIG AND THERES ALOT OF XTRA ROOM TO MOVE AROUND IN IT WHEN THE CAR IS TIED DOWN.
MH
MH;
I already have a 20 ft Pace being built to my specs, so it's too late for the aluminum suggestion.
May I ask what truck you're pulling with, and, if it's a 3/4 ton, have you noted how much your truck squats after you've loaded your car(before with empty trailer, versus after with car loaded)?
Bryon
