Old 09-06-2007, 05:08 AM
Default Correct sender for gauge?
Xavier For the fuel gauge check and make sure you have the correct sender in the tank for the gauge. There are 2 senders, one goes from low to high ohms, the other goes from high to low ohms. Your sender could be stuck on something in the gas tank and you would have only a sweep test and no correct reading. For the tach problem send the unit back to MSD and say there is no signal from the box. Start there. You didnot say which system you are using on the motor, you may need an adapter kit for the Tach from MSD for autometer. Rick Lake
