Old 09-08-2007, 04:50 AM
sideshow sideshow is offline
some of the wires from the main loom need to goto the etra plug on ecu which i supply
its much neater if i have the loom to mod cause some wires run to front of car
but i cut loom apart nd run wires to ecu or under dash so it looks neater
otherwise some pwer wires would run down left side of car to front of engine
the ecu reads the speed signal input then sends the sgnal up to dash
so its different to how it was originally set up
i can wait till u get the plugs theres no rush just thought i would see how things are going
there is no neut safety switch for the l76 ecu the std t56 gearbox has a reverse lockout which stops reverse being selected when driving
but im sure the tremec doesnt have that problem
so the neut switch is not needed
anyway if your nto in a hurry dont worry lets just wait and send the stuff when u get it
i now have a workshop so i am bit more organised and get thru abit more work than i was when i was mobile
i hope to get more into the new holden wiring and stuff
as the l76 is an aussie engine and the next popular engine will be the l98
which i already have stuff for
so let us know how things are going and ill go along with that
thanks
sidey
my website
www.sideshowsperformancewiring.com.au
