  #33 (permalink)
Old 09-08-2007, 06:39 AM
dlampe's Avatar
dlampe dlampe is offline
Cobra Make & Engine: B&B cobra (sold), Hurricane HMS1002 (sold), Kirkham 289 FIA, (sold) RCR GT 40(sold) SPF GT40 2122(sold) Hurricane HMS2002, (sold) RCR SLC (sold) GTR on the way!
The fittings are primarily Aeroquip. In some of the more complicated places I had to shop around a little with other suppliers to get exactly what I needed. The Weber banjo's are in fact aeroquip. They are only available in -6 and in blue and red. I usually use oven cleaner to take off the color but on these I used pecan shells in my blasting tank. Then I finished them with a brass wire brush. I was concerned with the size of the fuel line with a 600hp engine so I am using a 14 psi holley pump with a bypass regulator set at 3 psi. This provides tremendious volume at low pressure. This little unit came from Kinsler Fuel injection.
High Maintenance Racing Team
Run & Gun 2003 - 2013
