Old 09-08-2007, 10:45 AM
Allen Mulcahy Allen Mulcahy is offline
Can change trans to a TKO-600, 5th gear .82 or .64? I know this would help in the torque. Weight.... can build aluminum block to help with front end weight, cam specs 280/286 in/ex duration .590/.590 in/ex lift at valve 106 in centerline angle 114 ex centerline angle.10.5 compression ratio,Bore 4.310 Stroke 4.250, bigger bore w/smaller stroke or smaller bore bigger stroke?? Will probably not change rear end. THANKS for response Allen
