Old 09-08-2007, 02:04 PM
rbray rbray is offline
Default Ignition switch problems
Hi guys,
Today I had an interesting/scary problem come up.
It seems that when the key is in the ignition and turned to the on position ( not start ) and I reach under the dash and put a little pressure on the casing of the ignition switch the starter motor will crank.
This was a real surprise!
I put my head under the dash and all of the wires are securely connected to the switch.
Any ideas as to what is cause this. Is the switch bad? I think it’s an Autometer.
BTW. My dash is aluminum and is grounded to the frame. Could this have anything to do with my problem.
Roger
