Old 09-09-2007, 06:35 AM
Lowell W Lowell W is offline
Club Cobra Member
Cobra Make, Engine: SPF #1507 427 Dart Block Windsor
Pete,
I tried WD-40 and other similar products on the rubber bushings since that's what SPF recommended. Turns out that apparently was a solution to a non-existent problem, although I did replace the sway bar bushings with Poly at the same time I lubed the Rose joints so MAYBE that was part of the problem, too, although when I lubed the old bushings it made no difference.
Someone mentioned using some kind of lube for roller skate or skate board wheels or bushings or something like that... Sorry I can't be more specific but I never tried the stuff.
If you're really curious and really industrious you could try lubing one joint at a time to isolate the problem.
Good luck,
Lowell
