Old 09-14-2007, 11:50 AM
BDR561 BDR561 is offline
Cobra Make, Engine: BDR 559. 410 Stroker 72 block AFR205 Heads, Solid roller lifters, Comp Cams XR286, Eagle 4" stroke internally balanced with chevy journals, Oliver rods, Probe Forged pistons, Mighty Demon, Super Victor, MSD Digital 6.....
Here's a little additional info on the Frontier build quality for thos interested...
The MOST important part of your trailer is the one that you don't see!! The frame structure determines whether or not your trailer can handle the heavy loads on the long haul.
After your frame is painted and dried, it is then pre-wired. We use 3/4" exterior grade plywood to floor all of our trailers. Then we use 3/8" plywood to line the interior walls. This is sometimes upgraded to vinyl or even aluminum.
After using .030 gauge aluminum on the exterior walls and installing the top, Frontier Cargo pays attention to detail a little more than most manufacturers. Here are just a few examples of what makes a Frontier better than the rest!
Notice the wiring for the lighted tag holder. You will also notice a grease fitting on the ramp door hinge. Installing grease fittings on the hinges prevents rust
from setting in, assuring a smooth and quiet hinge operation that will last years longer than the competition.
Aluminum Cast Corners assures a roof that will stay leak proof for many years. When caulking ages over the years, it shrinks and cracks. Cast corners prevent this from being a leak problem. This is where 26 years of experience pays off.
Fender lights might not be a big deal, until you try to back your trailer at night. Then they are invaluable!
Door hold backs. Standard on every trailer, may seem simple, but try to load in a 20 mph wind without it. There's the experience paying off again!
Theft proof hinge bolts. Kind of like the special key used for lug nuts on expensive wheels. Ordinary wrenches and tools will not do any good.
Front Cast Corners Not only do they look good, but they insure that your trailer will stay leak proof for the long haul. Cast corners help make the transitions from the front and side leak proof for years to come. When you're shopping for your new trailer, ask your
dealer for cast corners. If they don't offer it, ask them to check into Frontier. Our cast corners are standard equipment on every trailer we build. It's just another reason more
people are turning to Frontier Cargo.
Looks like they pay attention to detail....
BDR 559
Indigo Blue, White Stripes
SBF 410
TKO 600 .82 OD (Road Race)
HP= Enough!!
