Originally Posted by Got the Bug
My clutch resevoir kept seaping, so Dynamic agree to send me a new one. They ended up sending the bottom portion of the unit (with a new o-ring).Doug
Doug, I'd advise changing everything including the top plastic piece. As SantaFe66 noted that plastic can distort with clamping, so that's why I got the complete kit from Summit and changed it all out, tightened the new setup very gently, no leaks since. BTW no need to bleed the system, the tubing from the bottom of the reservoir that goes over to the clutch master cylinder will maintain a fluid level in it (keep it pointing up when changing out the reservoir) and will be fine when you add new fluid to the new reservoir
