Old 09-16-2007, 10:52 AM
ENTDOC's Avatar
ENTDOC ENTDOC is offline
I realize that is the ideal turnout, but I would try 1 full turn and see what happens, if it helps then going up in the idle jet may be in order. On the other hand if it works and the A/F is good , then leave it out. I have found that when you are dealing with more exotic motors you have to fudge on the conventional wisdom with webers.
