Old 09-16-2007, 01:59 PM
EarlsflyinCobra's Avatar
EarlsflyinCobra EarlsflyinCobra is offline
Ouch Ouch Hot Sand
Cobra Make, Engine: Street Beasts w/302 Twin Turbocharged....Under Construction!!
Send a message via AIM to EarlsflyinCobra
Ahhhhhhhhhhhhhhh, the saga continues......I cleaned the throttle body as good as I could and ran a bottle of gum out injector cleaner through the system......took it out on I-95 and gave it a gooooooood run......all seemed to be well....then took it to the auto parts store and lo and behold, no codes found....then, since I had noticed it dragging a bit once in a while when I started it, just in the last week, I asked them to check the battery, alternator, and starter......went to start it and errrrrr, errrrrr, errrrrr, would not start.....removed the battery and took it inside and on the machine it showed a short in the battery....OK, trucks 2001 with original FORD battery, sooooooooooo, a new battery was purchased...another test drive and no other problems were noted....hopefully its fixed now
However, I must tell you of another GREMLIN that has entered my life.....about a week ago I went outside and started the truck, went back in for a moment, and upon returning found the truck locked....oppppps, must have acciently locked it....then later that day I started the truck and the doors immediately locked...hmmmmmmmmm, never done that before...shut it off, unlocked the doors and nothing.....hmmmmmmm, maybe I'm going wacky.....next morning got in truck and started it and doors immediately locked....bout jumped outta my shorts......I've started the truck about 10 more times since then and it has locked itself 3 or 4 of those times go figure...........................
Safe Flyin, errrrr Drivin, Earl
