Thread: PCV Valves
Old 09-17-2007, 07:29 AM
BDR561 BDR561 is offline
Cobra Make, Engine: BDR 559. 410 Stroker 72 block AFR205 Heads, Solid roller lifters, Comp Cams XR286, Eagle 4" stroke internally balanced with chevy journals, Oliver rods, Probe Forged pistons, Mighty Demon, Super Victor, MSD Digital 6.....
If I do the traditional setup, I will have to iether tap the intake for another vacuum source, or put a T-fitting in so the PB and PCV can share the same port.
I will check to see how my vacuum is effected with the PCV.
Thanks for your input
BDR 559
Indigo Blue, White Stripes
SBF 410
TKO 600 .82 OD (Road Race)
HP= Enough!!
