Old 09-18-2007, 07:27 AM
tbirdtess tbirdtess is offline
Default Sound right
Hello
I run an open rear do to the rules.
Mylesdw, That sounds right. The RR was the hottest tire after the feature.
What about even lighter rear springs? Or more rear weight?
My car is heavy already. So adding weight not direction I want go.
The handling was good until I changed the 302Ho to the 351W.
The extra weight in the 351W & more HP completely changed the car.
I need all the Help I can get. I have mid to lower finishing car. I want to improve that fact. I also run the Only Ford. Stubborn Frenchman I guess.
Here are some of the rules:
V-8 2bbl carb 8.5 compression + stock lift w/mec fuel pump, Automatic Trany, 15" DOT 70 series tires, open rear gear with max 3.73(I am aloud 3.90) all on a min 3400lb car & only 51% left side weight.
Did I mention No Racing spring or shocks(Most ignore this rule), I can't.
I can't find racing shocks for my car.
Paul
Racing FORD's is unpopular BUT I don't Care!
