Old 09-18-2007, 01:59 PM
mylesdw mylesdw is offline
Cobra Make, Engine: Ram 427 SC CSX6042. Chev 355. Quad Weber DCNFs
Send a message via ICQ to mylesdw
Originally Posted by tbirdtess
Hello
Mylesdw, That sounds right. The RR was the hottest tire after the feature.
What about even lighter rear springs? Or more rear weight?
I can't see that either of those two would help, the ARBs (anti-roll bars) convert body roll to loading on the outside tyres and the balance between front and rear roll stiffness effects understeer/oversteer. You need to decrease rear roll stiffness or increase front roll stiffness. Moving the ARB pick-up points gives the best adjustment since changing its diameter gives a very large change; the stiffness of a torsion bar goes up with the 4th power of its diameter, or to put it another way, if you double the diameter the bar will be 16 times stiffer! An alternative is to lessen the car's tendency to roll in the first place by lowering the centre of gravity.
Myles D-W
