Thread: Rear brake help
Old 09-20-2007, 06:08 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Hey Randy,
Make sure if you are running manual brakes that the bais bar setup is not binding. You might want to take off 1 side of the bais bar to free up the front or the rear to see if that solves the problem. This has happen to me. Or you might check that a caliper did not freeze up.
But you are noticing that both tire are dragging when trying to turn them I would check the bais bar.
Hope this helps
