Thread: Rear brake help
Old 09-20-2007, 09:00 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
If you have Wilwood brakes, your calipers must be centered on the disc--they have shims to do this--your metal to metal noise should be planely visable by looking for bright shiny spots---your comment about the parking brake says that you don't have it adjusted properly --the same guy probably installed all your brake compoments so I'd also check the fronts for proper mounting and adjustment
Jerry
