Old 08-19-2001, 09:07 PM
John Wais John Wais is offline
Cobra Make, Engine: Classic Roadster, 351Cleveland
Default Alignment
Petek
I have watched your build for at least 1-1/2 years and have modified items on my CR after watching what you did.
Looking good!!
I had my CR aligned at a good shop to the factory specs. It tracks well at speed and exhibits no bump steer (at least any of the bumps I usually manage to find locally). I did have bump steer before alignment along with being very loose at speeds over 90. It is now stable.
Just try to find a good shop which has the equipment to check all four wheels.
I had to make special retainers to prevent the upper A-frame from moving around after alignment because we could not get the nuts tight enough.
John W.
