Old 09-21-2007, 12:04 AM
Smokin427 Smokin427 is offline
Default TRW Piston Specs
I just bought a 427 short block with std boreTRW Pistons. It has a 428 crank. They are marked L 2298. I need to know the specs on these so I can determine compression ratio with 76 cc heads to see if they will work. I need to know the effective cc's of the domes and the compression height if possible. It would also be helpful to find out the piston od, distance from top ring to top of piston and the ring sizes. Does anyone know where I can find this info ? I have been searching the net but no luck. Thanks.
