Old 09-23-2007, 06:49 AM
Dwight's Avatar
Dwight Dwight is offline
Smile
Have your Cobra on the ground, correct air pressure in tires, frame/ ride height adjusted,etc. sit in the seat and have someone to hold the windshield in place. Check to see if your head/ eyes are above or below the top windshield brace. Use a protactor to check the angle. I think 45 to 53 degrees is OK. If you have a top then the angle will have to match the top. Side curtains sometimes can be modified to fit correctly. We have put a FFR hardtop on a Hurricane but had to cut the side curtains at the front and add a piece to the bottom.
Dwight
Same top
