Old 09-23-2007, 04:47 PM
cobred's Avatar
cobred cobred is offline
Cobra Make, Engine: ERA #698 428 Toploader
A cleaner way to check the push rod is to drive the car until you feel the brake problem. Then jack it up. Then with the wheels stuck, loosen the nuts holding the master cyl. to the booster or bracket/firewall. If the wheels turn free the problem is most likely the push rod length.
