Old 09-23-2007, 08:29 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by olddog
. The previous owner said the builder estimated 400 hp. Putting all the engine specs into my "virtual engine dyno pro" and "dyno2000," both software packages estimate 400 to 450 Hp at the flywheel.
My first impression, when I drove it, was that it was putting out about 300 hp maximum. The engine light was coming on. By the smell of the exhaust and the black sooty side pipes, I new it was running way too rich - which we all know will kill Hp. Well the seat of my pants is not an accurate dyno, but with 3.50:1 rear gears, you could stomp it at any rpm in 1st gear, and it could not break the tires loose (P295 50R 15 BFG T/A).
I've been working my way through the EFI system. The engine light code was caused by the right O2 sensor plug being loose. That helped a little. The fuel pressure was 43 psi and should have been 40. Correcting that made some improvement. Today I cleaned the mass flow meter - it's a hot wire type, and wow! What a kick in the pants. I was not expecting the tires to light up just stepping on the throttle at 1500 rpm (the cam lopes until 2000 rpm)
I figure a 240 lb passenger is like a 40 Hp reduction. The power increase is like taking two passenger out of the car, hence my 80 Hp increase. .
The best (easiest) way to tune your car to its best potential is to take to a dyno shop and have it chassis tuned. Numbers don't lie.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
