Old 09-24-2007, 09:01 AM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by psychoSEAL
Bobcowan, In reply to your solution. I notice that approx. 2" behind the thermostat housing there is a 1/2" stainless bolt. Would this be an alternate sight of hooking the hose to the water pump instead of drilling?
That's normally used for a heater hose port. But you can also use it for a bypass port. Put in a 90* heater hose fitting and run it down to the water pump.
If your water pump has threaded ports, this would be a good place for AN fittings and hose.
