Old 09-24-2007, 07:47 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Question
Originally Posted by olddog
Rear Gear Ratio??
When picking a rear gear ratio, its more like picking a rear gear - Tranny combination.
What you need to ask yourself is
1) What will be my cruising speed (mph) and what rpm do I want my engine running? This will determine final drive overall gear multiplication.
2) What overall gear multiplication do you want for 1st gear to get a good holeshot?
3) How closely do you want your gears spaced? This will determine whether you want a 4, 5 , or 6 speed tranny.
If you can answer all these questions, figure out what the numbers are, then they will determine which tranny / rear gear arrangement will be best for you.
In your case, I'd say either swap the TKO for a wide ratio toploader and keep the 3.5 rears, or switch to a TKO600 with 0.082 5th, again keeping the 3.50 rears, but obviously that's something you need to decide for yourself.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
