Old 09-25-2007, 04:24 AM
Rickd Rickd is offline
Default GForce Street T-5 Transmission
I am in the tranny selection phase and had considered the TKO 600. I have read good things about the GForce Street T-5. Looks like beautiful, strong gears (will handle 600 hp 500 lb Tq in a 3300 lb car with drag radials on). I really like the OD gear which is .73, which is a nice all around cruising gear. The TKO's .64 results in a huge rpm drop from 4th and the TKO's .82 option has you running higher rpm's at 80 mph on the Florida freeways. The .73 looks like an optimal gear for a primarily street run car. Any experience with this tranny?? Also from a cost standpoint it is virtually the same as the TKO.
Rickd
