Old 09-25-2007, 06:27 AM
jwd's Avatar
jwd jwd is offline
When this problem occurs, check to make sure that the throttle is returning all the way and resting on the idle adjustment screw. If not, check to make sure that the choke is fully open. Sounds like the advance weights in the dist. might be hanging up. That would cause exactly what you are experiencing.
