Old 09-25-2007, 02:48 PM
Rick Parker's Avatar
Default Additional Current info as of today
I called and spoke to the tech department at Kendall today (9/25). The fellow was very cordial and free with information once he realized I wasn't an EPA spy (!) .
Regading the lack of Zinc which has been on a slow decline for about 8 years with the biggest hit in the last year according to him he suggested this:
http://tds.econocophillips.com/catal...0TDS%20Web.pdf
It has a very high zinc content (1450 PPM of ZDDP) and is compatible with gasoline engines, ideal for high spring pressures in flat tappet cam engines.
This was their response to an Email inquiry prior to my conversation:
Current ZDDP levels in the 10W-40 viscosity grade are 770 ppm. For engines equipped with flat tappet cams you will want a product with a higher concentration of ZDDP. I recommend going with the Kendall Super-D 3 in either 10W-30 or 15W-40. The ZDDP levels of these products are 1450 ppm which is sufficient protection for flat tappet cam equipped engines.
Rick
