Old 08-20-2001, 07:10 PM
frankym frankym is offline
Cobra Make, Engine: ERA 575 with Shelby Aluminum 427 Stroked to 468
I have a wildwood pull style hydraulic clutch slave cylinder and a centerforce racing clutch. One thing you will note is that the slave cylinder you buy has one ring nut on one side of the stem rod and the other end is simply threads, you will be better off getting that same ring nut for the other end, I used the one from my old slave so inquire about that when you order your slave. Go to wildwood's website.
