  #21 (permalink)
Old 09-26-2007, 05:25 AM
Default Motor power not match to gearing
Olddog Where is your cam power come in?? you want to be 500-750 rpm inside that power band. Sound like the motor is lugging along at highway speed. You forgot to take into the formula of resistance of the car and how much added HP is needed to push the car through the air. 3.73 min gearing is needed. If you could get a 3.90 gear this work be better. You would still get to use 1 and 5th gears alot more without quick shifts and motor lugging. You are not the first to under gear your car and will not be the last. Rick L.
