Old 09-26-2007, 07:04 AM
SSSammy's Avatar
SSSammy SSSammy is offline
Default Solution to above elec problem and new question
The major elec outage resolved down to one heavy wire going from the circuit breaker to the ammeter, then to the fuse block terminal 1L. This circuit goes through both of the high amperage connectors. In the big red connector, one of the pins was not pushed all the way into the housing, so it was not making contact. Pushed pin in .. lights, horn, etc.
Bob or anyone, regarding the sidepipe rear hangar straps .. one corner is clipped off on each strap. How do I orient this corner, up, down, inside, outside? There must be a reason for it
Sam
