Old 09-26-2007, 08:53 AM
xlr8or's Avatar
xlr8or xlr8or is offline
The springs you have should be able to pull it back. There should be little to no resistance in the weights moving back and forth. I bet if you clean up the pivots and the shaft it will return just fine.
Jimi,
The problem I had with this was the same way with it taking a full heat soak to cause the issue. Once cleaned out it worked as expected.
