Old 09-26-2007, 02:25 PM
767Jockey's Avatar
767Jockey 767Jockey is offline
The 351C takes the same bellhousing as the 351W. Shouldn't the slave from a Windsor bolt right up to the Cleveland, assuming that as with most slaves it's somehow mounted to the bellhousing mounting bolts? I have to do the same job down the road, as my CCX with 351C had an automatic when I got it and I'm converting to a TKO600. If I'm wrong in my assumptions about the W setup fitting the C, then I've got some learning to do was well.
