Old 09-26-2007, 02:39 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by JoshBiz
Would you rather a 390FE or 351w (stroked to a 427)? The 390FE would be more origanal than a 351w But there is a lot of great after market parts for the 351w. They are both great motors but I am unsure what I would rather have and would like to hear your opion.
You can stroke a 390 as well, 4.08 bore, 4.250 stroke = 441 cubic inches.
4.08 bore , 3.98 stroke = 414 cubic inches.
You can get reasonably priced parts for either engine, but obviously there is a much greater range of parts for the 351W.
Starting with a factory cast iron block, I would guess the build cost wouold be similar no matter which engine, either using a stock crank or a stroker crank.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
